chrisg88
Message 1 of 7
BT TV Youview 4k UHD box stuck in maintenance mode
Hi
I've come to switch on my Youview 4k UHD BT TV box this morning and it is stuck in maintenance mode. Despite trying all five options on this screen I end up back there. Can anyone advise how I can reset the box? Or do I need a replacement?
Many thanks in advance
Tags (3)
6 REPLIES 6
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 7
Re: BT TV Youview 4k UHD box stuck in maintenance mode
Hi @chrisg88
if you select maintenance mode option 2 what actually happens .. ie what occurs before you end up back at the maintenance mode options again ?
chrisg88
Message 3 of 7
Hi
It either says 'sorry, selected option failed' and returns me to the maintenance menu, or it restarts, tries to load up (I see the BT TV and YouView logos) then I'm back at the maintenance window again. If it was a laptop/PC I'd say the hard drive was gone!
Cheers
Chris
zulu17
Distinguished Guru
Distinguished Guru
Message 4 of 7
Assuming you have a BT Tv contract ring up to report a box fault.
chris98765
Message 5 of 7
Hi,
I have the exact same problem, did you manage to resolve the issue? I'm not with BT so they're not going to help me.
chrisg88
Message 6 of 7
Hi there
Basically the hard drive had gone, so I had to get a new YouView box. BT came out and replaced it and the newer model is much more stable. Sorry that doesn't help you much!
Cheers
Chris
chris98765
Message 7 of 7
I have the exact same problem, and I'm not with BT so they're not going to help me.
Any ideas? Isn't there a way to exist maintenance mode once you're in it?
Thank you,
Chris
