Mcleod
Message 1 of 6
BT TV a with Prime Video
We’ve just had BT TV installed and we don’t seem to be able to use Prime video.  It allows us to log on, select a programme but it just then drops out.  I have seen quite a few people with this problem but not able to see the “cure”. If anyone can help it would be greatly appreciated.
5 REPLIES 5
Matt-S
Moderator-Retired
Message 2 of 6
Re: BT TV a with Prime Video
Hi @Mcleod,
Welcome to the Community and thanks for posting.
Sorry to hear that you're having problems with BTTV.
How do you have your BTTV box connected to your hub, ethernet cable or powerline adapters?
Matt
Mcleod
Message 3 of 6
Power line adapters
Matt-S
Moderator-Retired
Message 4 of 6
@Mcleod
It's possible that the Powerline adapters have become out of sync with each other. Can you disconnect them and complete the setup process again?
If this doesn't work can you factory reset your BTTV box and check for any updates once the reset has completed?
Matt
Mcleod
Message 5 of 6
Ok but I’ll have to do it tomorrow Now. Thank you
Mcleod
Message 6 of 6
Have reset the mini connectors and so far it’s working with Now TV. We’ll see how it goes. However I do have Prime video and that seems to be doing the same. Trial and error I suppose. The Ethernet cable was in socket 2 on the connector so I’ve changed them to 1. Anyway as I said we’ll see how it goes
