Message 1 of 17
BT TV box pro remote
My question is about by TV box pro remote and am missing stop button. I can overcome no close button but how do I stop a recording playing and return to live TV etc
16 REPLIES 16
Message 2 of 17
Re: BT TV box pro remote
The record button is used to delete items in your recordings list.
You can also press "R" on the TV guide which will show you a list of options.
Message 3 of 17
@terry821 thanks for your early reply, but my query concerns lack of 'stop' button. If I am watching a recording and want to stop it to return to 'live' TV how do I do it.
Message 4 of 17
Press the back button multiple times, or press the YouView button or TV Guide button to select something else to watch.
Message 5 of 17
@DarrenDev thanks Darren I assume anyone of these options would stop the recording playback and take me to that point if I wanted to resume at a later date. I expect I would have discovered this myself by playing around but your help is appreciated and easier. Thanks again.
Message 6 of 17
Lack of close button is irritating. Would be great if it could be programmed so holding down the back button acts as the close button
Message 7 of 17
I miss the delete button more - I used it for deleting recordings, and backspacing when typing in search. The latter will be less important when voice search is enabled. Also, the back button is in a different place to all other remotes I've ever used - being above the d-pad is weird.
I assume the new remote was designed based on usage figures of existing remotes though - culling lesser-used keys.
Overall, I prefer the new remote.
Worth noting that you can still use the old remote with the new box if you really hate using the new remote.
Message 8 of 17
Is there a photo of the new remote anywhere. I find the current remote difficult to navigate due to sight problems
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Message 9 of 17
From the BT newsroom: BT unveils BT TV Box Pro
 (click the image to zoom)
Message 10 of 17
Great thank you that does look much simpler and better
Helpful Post?
