des480
Message 1 of 24
BT TV channels not working with Netgear router
Due to my BT HH3 router randomly dropping coonection to the internet I have replced it with a netgear r6400 router. Internet now seems to be more stable and, dare I say it, with better range than the BT HH3.
Howver my problem is that I cannot get the BT channels to work on my Youview box ( relabelled Humax box). I think it may be a multi casting problem. Has anyone had any success with a netgear r6400 and BT TV , can you tell me how to set up the Netgear router.
23 REPLIES 23
Distinguished Guru
Distinguished Guru
Message 2 of 24
Re: BT TV channels not working with Netgear router
Have a look at this thread
https://community.bt.com/t5/Connected-Devices-Other/R6400-AC1750-Netgear-Router-and-YouView-box/m-p/...
not sureit addresesyour multicasting issue though.
des480
Message 3 of 24
Have already enabled IGMP but still no joy.  Netger support state ther is no solution which I find strange. Any other suggestions?
Thanks for the quick response BTW
Message 4 of 24
BT TV Expert
BT TV Expert
Message 5 of 24
Hello @des480
If you're continuing to have issues, please let me know by Private Message and I will see if I can help.
Martin.
des480
Message 6 of 24
Hi Martin any help would be appreciated how do I private message you.
des480
Message 7 of 24
Sorted - have now sent private mesage
des480
Message 8 of 24
Hi Martin,
Many thanks for sorting out the problem, everything now working beautifully
Jonnyp1
Message 9 of 24
I have this issue also and have attempted to solve it by installing the Tomato firmware. Do you mind helping me also?
Thanks in advance
Jonnyp1
Message 10 of 24
Hi
Is this a simple fix?
