vhizz87
Newbie
Message 21 of 24
Re: BT TV channels not working with Netgear router
thanks ive got it working now..couple of settings changed withing the router log in webpage and everything works fine.
Message 22 of 24
Perhaps if you would like to mention what settings you changed, it might help other users?
dave3d
Message 23 of 24
I got it to work at long last.
After making sure I had the latest firmware, I did a factory reset on the router.
One of the options when the initial configuration came up, asked about streaming BT channels.
I do not recall seeing this when I did the original setup. I must have either missed it or it is a new feature with later
firmware. I ticked the option and voila it worked. It must preconfigure a miriad of other settings.
Message 24 of 24
That does sound like a firmware update, as nobody has mentioned that extra setup option. I am sure that will help others. Thanks.
