Message 1 of 11
BT TV error message BTP_20000
Hi,
Showing error message BTP_20000
Tv channels working through aerial, apps such as Iplayer working through the internet. When I try to access an internet channel it shows error BTP_20000. If i try bt player it shows the error BTP-115C. BT tv should have been activated 7th April. Ethernet cable connects youview box to the smarthub. No problems with internet connection or tv signal.
Hoping someone here can help me as not luck on the phoneline so far and latest suggestion was to send out engineer. So hoping to find a solution on here before doing that.
10 REPLIES 10
Message 2 of 11
Re: BT TV error message BTP_20000
Welcome to this user forum. @magic_magilton
See https://community.bt.com/t5/YouView-Boxes/Btp20000-error/m-p/1737598#M87739
As in that case, it looks like moderator help may be nneded.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Moderator
Moderator
Message 3 of 11
Hi @magic_magilton,
I'm sorry to hear about the problems you have. We'll certainly be able to look into it for you.
To reach my team, click on my user name and then click on contact the mods on the left hand side. That'll send us through a trouble ticket. It may take us a couple of working days before we can get back in touch with you.
DanielS
Venomx
Expert
Message 4 of 11
This was happening to me when i first installed it. Try resetting your router !
Moderator
Moderator
Message 5 of 11
Hi @magic_magilton,
Please can you try resetting your router as suggested by @Venomx? If that doesn't work please send in your details as advised by @DanielS and we'll be able to take a look at this for you.
PaddyB
Message 6 of 11
Hi,
Reset the router, but no luck i'm afraid. I will send through my details.
Thanks,
Moderator
Moderator
Message 7 of 11
Hi @magic_magilton,
Thanks for sending over the details. Perhaps @Gemma_P might be able to offer some advice with this. Any ideas Gemma?
Cheers
David
Moderator
Moderator
Message 8 of 11
Hi @magic_magilton,
I tried calling today, sorry I missed you. Are you still seeing this error code? Can you post back and let me know how you're getting on?
Cheers
David
Moderator
Moderator
Message 9 of 11
Hi @magic_magilton,
I tried calling this morning, sorry I missed you. Can you let me know if your BT TV issue is sorted?
Cheers
David
Message 10 of 11
Hi David,
I've been out the country for a while.
Just to let you know that the problem was sorted quickly once I had posted to this forum.
