paulplatts
Message 1 of 5
BT TV remote control code for JVC LT-32C670 television
Hi BT,
I believe the above tv is actually manufactured by Vestel, but the offered code of 2811 does not work. Are there alternatives please?
Thanks in anticipation.
Paul Platts
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: BT TV remote control code for JVC LT-32C670 television
Hi @paulplatts Welcome to the forum and thanks for your post about TV remote codes.
Check out How do I control my TV with my BT TV remote control? You probably already have but did you try the JVC code 2788 to see if it would work?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
paulplatts
Message 3 of 5
Hi John,
I did, but it didn't, I'm afraid.
Regards
Paul P
Moderator
Moderator
Message 4 of 5
Hi @paulplatts I have looked around the forum and can see previous threads re this issue with JVC but no solution. I  therefore checked the Manual and it does mention the old BT Vision service so maybe these codes will help
"BT Vision
The codes for controlling your TV using a BT Vision Remote Control are 0000, 0019, 0725, 0669, 0016, 0152, 0184, 0197, 0198, 0225, 0244, 0324, 0325, 0339, 0319. For instruction on how to use the code see your BT Vision instruction manual."
Cheers
John
Kudos”
paulplatts
Message 5 of 5
Thanks John, much appreciated.
