Newbie
Message 1 of 2
BT TV remote not working properly
My BTTV remote control is not working properly. The buttons are very stiff and not easy to use, the back button doesn't work and the pause button as well. getting fed up as nothing I try to fix the problem works.
1 REPLY 1
Message 2 of 2
Re: BT TV remote not working properly
