Message 1 of 10
BT TV tv guide
Hi
I upgraded my broadband to now include BT TV with the Big Entertainment package from Now TV.
In the pictures I have seen it clearly shows the now tv channels and Netflix and Prime integrated into the main TV guide of the box. This is not case with mine. I have to go into the App section and select Now tv and then Tv guide to watch live channels. Seems a small issue but I'd like the convenience of having everything in the one tv guide. How do i get around this please
Thanks.
9 REPLIES 9
Moderator
Moderator
Message 2 of 10
Re: BT TV tv guide
Hi @Kevicr and thanks for posting.
Are you seeing the Sky channels in the BTTV guide? When do=id you place the order? Has it fully closed off? Have you tried resetting the box?
Cheers
David
Message 3 of 10
Re: BT TV tv guide
Hi @DavidM
Yes according to myBT app the order is now closed.  I placed the order on the 27/02. Box arrived yesterday and BT closed the order today.  No sky channels are appearing in the TV guide. I factory reset box and still no joy.  Although I have just turned the TV on and a message on screen said there will be a channel retune tomorrow.  Maybe that could be it?
Moderator
Moderator
Message 4 of 10
Re: BT TV tv guide
Thanks for getting back @Kevicr.
It's probably best to see what the retune does. If there's no change after that get back to me and we'll take it from there.
Cheers
David
Recognised Expert
Message 5 of 10
Re: BT TV tv guide
@Kevicr
If it's the TV giving the message about a retune then that's just a Freeview retune which is happening frequently these days.
Did you reboot the HomeHub as that's often necessary to pickup the changes to susbscription channels?
Moderator
Moderator
Message 6 of 10
Re: BT TV tv guide
Good point @TimCurtis.
Cheers
David
BT TV Expert
Message 7 of 10
Re: BT TV tv guide
Hi @Kevicr
As well as the steps mentioned by others on this post. It would also be worth running a software update from the settings on the BT TV box. Thank you,
Message 8 of 10
Re: BT TV tv guide
It was a message from BT not a generic TV one.
I'm at work at the moment so can't check until just after 2pm
Thanks guys
Message 9 of 10
Re: BT TV tv guide
@Gemma_P  software update was the first thing I did. I'll look again when I get home
BT TV Expert
Message 10 of 10
Re: BT TV tv guide
Hi @Kevicr,
Thank you, if you still have problems once you're back home and re-tried please drop me a private message with your contact details and I'll try and resolve this for you. Thanks.
