JimboAlfie
Message 1 of 10
Tags (2)
9 REPLIES 9
Moderator
Moderator
Message 2 of 10
Re: BT TV
@JimboAlfie I'm so sorry the community was experiencing problems the other evening and your post is blank. If you reply back it will work now.
JimboAlfie
Message 3 of 10
Re: BT TV
I get audio playing on program and can’t get it off . I have followed the correct procedures but it’s still on. Advice would be welcome
Guru
Message 4 of 10
Re: BT TV
Hi, you mean the “Audio Description”?
Stew
JimboAlfie
Message 5 of 10
Re: BT TV
Yes sorry
Guru
Message 6 of 10
Re: BT TV
Which remote control do you have? I have the Youview one and it has a button on the bottom left, AD. Try pressing that and see the response on the tv screen.
Stew
Moderator
Moderator
Message 7 of 10
Re: BT TV
Hi @JimboAlfie,
Thanks for confirming.
To turn off Audio Description, press the AD button on your remote control, or press the YouView button then go to Settings > Subtitles & Accessibility > Audio Description.
Let me know if that has helped?
PaddyB
JimboAlfie
Message 8 of 10
Re: BT TV
Thank for getting back I have done that before posting the problem. If I’m watching programmes recorded will it switch it off or will I have to wait till recording is ended
Many Thanks
James
Guru
Message 9 of 10
Re: BT TV
Not sure, what have you tried?
Stew
JimboAlfie
Message 10 of 10
Re: BT TV
Hi
Screen shot of what I have done as requested by Paddy
BT TV
Hi @JimboAlfie,
PaddyB
