Message 1 of 4
BT Ultra HD YouView Box from Amazon
Hi, I am looking at buying the above box from Amazon, I am a BT Infinity 2 Customer with BT Sport, I do not subscribe to BT TV.
I wanted to know what services can I use with no extra subscription from BT? What cant I use? Do I contact BT and get anything enabled? I assume Netflix & Now TV will be ok?
Any thoughts appreciated, Thanks.
3 REPLIES 3
Expert
Message 2 of 4
Re: BT Ultra HD YouView Box from Amazon
There's only one UHD programme available on BT TV and you'll need to be a BT Sport subscriber to get it. You will, of course, get the available, for your area, Freeview channels.
Message 3 of 4
You'll also get the Catch up apps (bbc iplayer etc) and Netflix will work also. In case you aren't aware, Now tv on a Youview box is only the cinema pack in sd. Sport or Entertainment is not available on Now tv on Youview.
Message 4 of 4
Thanks for info, especially the Now TV restrictions!
