Jonovich
Message 1 of 6
BT Ultra HD package not giving me AMC HD Channel
Hi Folks,
Can anyone with the Ultra-HD (Total Entertainment package) confirm if they can get the AMC HD channel? I was led to believe from the advert that it is part of the £15 month package, but when I try and access it, I get a message to say it's not part of my subscription? I've called and spoken to couple of BT support folks, but nobody has been able to get it working, I just wanted to hear if someone else on this package is definitely getting this.
Thanks in advance,
Jono
5 REPLIES 5
Distinguished Guru
Distinguished Guru
Message 2 of 6
Re: BT Ultra HD package not giving me AMC HD Channel
Yes you should get both the AMC standard definition and HD channels with that package, If you are not  but are receiving the other channels then they have simply not set up your package correctly.  AMC is currently a bonus channel.
BT TV Expert
BT TV Expert
Message 3 of 6
PM me your details and I'll get it sorted for you, will check if any other customers are missing it too.
Steve
BT TV expertSteveM
Show your appreciation!
Kudos”Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
Jonovich
Message 4 of 6
Thanks Steve, you have a PM with my details.
Cheers,
Jono
BT TV Expert
BT TV Expert
Message 5 of 6
Thanks, try it now 😄
Steve
BT TV expertSteveM
Kudos”Kudos”
Jonovich
Message 6 of 6
Hey Steve,
That's fixed - you're my hero!
Cheers,
Jono
