columritchie
Message 1 of 6
BT Ultra HD vision box, not able to log in via the APP
I've a BT Vision Ultra HD freeview box, which I connect to via my mobile phone and the BT Vision APP.
Up until a few days ago, all was fine, I've had to change my mobile over to a new phone, however I can't pair BT box with the APP on my phone.
I can log into BT.Com , so I know the account details are still working (I no longer have had a BT line/broadband for 4 years or more).
I'm looking to be able to setup remote recordings, even trying the Humax App, but it's looking for a reg code which doesnt appear to be on the box software.
Any ideas how I can get my BT Box registered ?
Many thanks in advance
Colum
5 REPLIES 5
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 6
Re: BT Ultra HD vision box, not able to log in via the APP
I believe that Youview removed code-based pairing in the Next Gen UI because the automatic pairing is far simpler and they  wanted to move away from manual methods of pairing.
So  @columritchie can you confirm the software version on your Youview box . the latest for the Bt 4K UHD iT400 is 31.28.0
Also what is the version number of the Youview app that you have on your phone.
columritchie
Message 3 of 6
Hi Zulu17
I've just checked and my BT 4K UHD iT 4000 i s running the software 31.28.0
The Youveiw APP, is the current one available via google ver 3.1.3
And you could be right, as I thought previously I just paired without having to log into BT.
cheers
columritchie
Message 4 of 6
bump
what version of the app allows to pair over the wifi only i.e. without logging into BT
BTW I can log int my 'BT account" via laptop, just wont via the app 😞
TimCurtis
Recognised Expert
Message 5 of 6
There are 3 apps you can use (on iOS atleast):-
1. Youview
2. BT TV
3 TalkTalk
The latest BT TV app I believe requires you to log into a BT account first but the others don't need anything like that.
I have found issues in the past when you're using multiple switches or Powerline adaptors as a fraction of a second delay can affect the pairing process.
columritchie
Message 6 of 6
Hi TimCurtis
My telephone isn't with BT, and I'm only using the BT Vision box for the Freeview channels only.
I can log into my account on the BT website, but it wont let me log in via the BT Vision App
Though I see the Youview does 😄
