boltonde
Message 1 of 2
BT Vision / Youview
I've ordered a Youview box to replace the Vision.  Can I use them in conjunction so I can still view the recordings, if so how does it work?  thanks
1 REPLY 1
skappy70
Recognised Expert
Message 2 of 2
Re: BT Vision / Youview
Yep you can connect both boxes to your Internet but only the Youview box will have your subscription and you'll only be able to view Freeview recordings on your Vision box, BBC Iplayer and All 4 will work on the Vision box and it'll get software updates if left connected.
