roseview
Message 1 of 2
BT Vision - causing lock up. What is the point of having it?
We've been thinking about giving up our Sky and sticking with our Youview box which we have with BT Vision.
However, everytime we go to the BT Vision section it just seems to cause a lock up of the system and the box has to be switched off to overcome this. As a result I'm wondering what the point is in having this service at all?
Any ideas what the problem is or how we can overcome it?
1 REPLY 1
scointer
Recognised Expert
Message 2 of 2
Re: BT Vision - causing lock up. What is the point of having it?
Unfortunately I have to agree with you, everytime I try to do a couple of things on the vision section the box just slows down and eventually just stops, all I can do then is hard reset it but if it is recording something at that time the recording fails it is very frustrating...
I am hardwired to the hub and have a 50mb speed so that shouldn't be an issue really.
