Mauzeit
Message 1 of 6
BT YouView - BTP-15000 (Unable to access channels I'm paying for)
I'm a new BT customer and had my broadband set up on 17 April, with a landline/broadband/BT TV package.
However, when I set-up my BT YouView box, I can't access the BT Player or any of the subscription channels I should be able to watch.
The screen shows a message explaining that I need to set up a BT TV account, and the error code BTP-15000.
I called the number on the screen and spent 40 minutes talking to someone at BT who's only advice was to turn it off & on again. To no avail.
Is there information missing in my BT TV account or something ? Is it possible to get some assistance getting this sorted from the mod team here ? That would be amazing !
Thanks.
5 REPLIES 5
Mauzeit
Message 2 of 6
Re: BTP-20000/ BTP-15000/ BTP-155c
Apologies for replying to this a year later, but I'm having the exact same problem & received zero help from the number I was told to call.
I even tried explaining that it might be something to do with my account information as you explained, but to no avail.
What can I do to start accessing the channels I'm paying for?
Thanks.
PaddyB
Moderator
Moderator
Message 3 of 6
Re: BT YouView - BTP-15000 (Unable to access channels I'm paying for)
Hi @Mauzeit,
I'm sorry you haven't been able to use your new BT TV service. The error message usually means that the BT TV service hasn't been correctly set up on your account. I'll be able to get this corrected for you.
Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Mauzeit
Message 4 of 6
Thanks for getting back to me so quickly, have done so !
Gemma_P
BT TV Expert
Message 5 of 6
Hi @Mauzeit,
I have had a look and can see the service went to trusted today. Is it still coming up with that error for you? If there's still an issue I'll have further look. Thank you,
Gemma
Mauzeit
Message 6 of 6
Hi @Gemma_P
All sorted on my end now, thank you very much !
