Message 1 of 6
BT YouView Box App Issue (not working)
Hi Forum,
This afternoon I wanted to watch Now TV and the App would not work, every time I tried it just went back to normal TV channel, i.e. BBC 1 for example. I have tried to reconnect my BT WIFI smarthub and change the ethernet cable, but nothing is working to view any Apps now. This morning it was fine and I had not touched anything when I came back to my BT to view.
Is there is issue.
Thanks and Regards,
ZXSpec
5 REPLIES 5
Expert
Message 2 of 6
Re: BT YouView Box App Issue (not working)
Try rebooting the Youview box
Message 3 of 6
Thank you. Re-booting worked.
Expert
Message 4 of 6
If it happens again, reset the box, if that doesn't work check for software updates and app updates. Then try restarting again... It normally clears any issues
Message 5 of 6
Hi NigelB72,
Thank you. I will do this if it happens again. So far works fine now.
Thanks for the help you provide on this forum.
Expert
Message 6 of 6
No worries 👍
