Mp1
Message 21 of 23
Re: BT Youview box and Humax PVR controller clash
Zulu17 I turned everything off and started again and it worked. The remotes operate independently for each box now - thanks. I do have to press the source button on the tv to get to either the bt youview AV3 or the humax on AV2 - do you know if there is another way to move between both boxes? Thanks
Cr121624
Newbie
Message 22 of 23
Hi iv been struggling with this all week end and a 10 second look on here solved it ! T WAS DRIVING ME NUTS 🥜
MartinC007
Message 23 of 23
Thanks, that worked for me, although I did have to switch off and on the Humax before it accepted the 0/OK combination.
