Distinguished Guru
Distinguished Guru
Message 21 of 38
Re: BT Youview box and Prime video app
The Issue in the thread is specific to the ATP tennis  full match replays not a general  one relating to the Amazon player use of  the insufficient/low bandwidth error message.
NigelB72
Message 22 of 38
The OP mentions that she's having problems with the tennis and says that she only subscribe to Amazon to watch that. However, the low bandwidth issue is not just isolated to the tennis...
Distinguished Guru
Distinguished Guru
Message 23 of 38
The issue that this thread was raised for is the full match tennis replay content giving a probable misleading error .
saying you have a solution for some other instances whereby the same error message is displayed does not get us any further with the specific problem reported which the mods I believe have passed to BT Tv and I would like to understand how it is progressing.
If you would like to check whether you can view the full match ATP tennis match replays  on your Prime Video Player on your T4000 then that would be confirming whether you are experience the same issue or not.
Moderator
Moderator
Message 24 of 38
Hi @zulu17,
Thank you for posting.
I'm sorry I haven't had any update from my colleagues in the BT TV team regarding the "low bandwidth error" affected the tennis replays.
I'm chasing an update and I'll post back as soon as I know more.
Please accept my apology for the delay.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
ken2222
Message 25 of 38
same here on both boxs my t400 boxs and my t2100 bt boxs
NigelB72
Message 26 of 38
I've just tried and it's working fine for me. Someone else has posted on another thread that virgin media customers are also having issues
Andy005
Message 27 of 38
Did you try the Highlights, a match replay or both? It's the match replays that won't run, the Highlights will.
NigelB72
Message 28 of 38
I tried the highlights.. I'll try a match.. two ticks
NigelB72
Message 29 of 38
I can confirm that they don't work 😂
ozsat
Expert
Message 30 of 38
It was me that posted about VM.
The same assets fail on both VM and BT - and seems to be most sport replays.
using Superfast Fibre 2 Unlimited with BT Max 4K package.
