Cherubeyes
Message 1 of 2
BT Youview box will not wake up.
My BT |Youview box will not wake up. It has only one blue light. And keeps going around on a loop.
I have tried the recommended attempt to reset the device. However, when I press the Power button the Maintenance Mode wording comes up. But then the screen goes black and nothing happens. I have tried this a number of times.
And nothing happens. What can I do please?
1 REPLY 1
NeilO
Moderator
Moderator
Message 2 of 2
Re: BT Youview box will not wake up.
Hi @Cherubeyes, I'm sorry you're BT TV box isn't working, I'm afraid there isn't anything else you can try if the reset isn't working. If you have a BT TV subscription get in touch with the faults team on 0800 800 150 and they'll sort you with a replacement.
