kkkk
Message 1 of 3
BT Youview iPlayer smart hub 6 stutter on 55mb infinity
iPlayer works perfectly with a now TV box, but the bt tv T2200 stutters sometimes every minute at worst, normally for split second then continues. Have it connected to powerline adapters.
I see this is not the first post with regard to this but I have not seen a solution. As I said, with a now TV box it's faultless using exactly the same setup.
2 REPLIES 2
kkkk
Message 2 of 3
Re: BT Youview iPlayer smart hub 6 stutter on 55mb infinity
The box and app software are all up to date and the powerline adapters have all been reset.
kkkk
Message 3 of 3
For information to others who may have the same problem, It affects the T2100 and T1000 boxes aswell as the T2200.
The current temporary fix seems to be to use iPlayer in standard definition, not high definition, in the iPlayer settings.
On the Youview forum there are numerous pages on this problem with no sign of a fix in sight.
