davebedson
Message 1 of 2
BT Youview won’t fully boot up - DTR T2100
My youview box won’t fully start up.
After loading I just get a black screen.
Fault appeared week before last - about the time the latest firmware came out.
Possible corrupt on install?
Tried maintience mode and all reset options but every time every option fails.
I have another youview box and swapped it out - this works fine
I’ve tried the faulty box oh another TV with no luck either.
I’m guessing the latest firmware has corrupt on installing? Or there’s a faulty part?
1 REPLY 1
JohnC2
Moderator
Moderator
Message 2 of 2
Re: BT Youview won’t fully boot up - DTR T2100
Hi @davebedson Sorry you are experiencing a fault with your BTTV Youview box.
Have you got this resolved? If not we will be happy to help you further if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
