Cmh123
Message 1 of 6
BT box keeps loosing internet connection
Had my BT box for a few months and it seems to loose internet connection quite often. Anyone else having these issues.
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: BT box keeps loosing internet connection
@Cmh123
Which box?
Cmh123
Message 3 of 6
My tv box. Wi fi is fine but the tv box keeps loading internet connection. It’s getting annoying now as you can’t actually watch anything
Keith_Beddoe
Message 4 of 6
Thanks, your post is now on the correct thread.
I assume you are a current BT TV customer, and you cannot watch any of the subscription channels?
How is the BT TV box connected to the BT Home hub?
Cmh123
Message 5 of 6
We have wired extenders in place. Some days it’s fine then other days it just drops connection all the time
Keith_Beddoe
Message 6 of 6
I assume you mean powerline adapters?
The only ones approved for BT TV, are the BT Mini connectors which are available at a discounted rate for BT TV customers.
https://community.bt.com/t5/YouView-from-BT/How-to-connect-YouView-Box-when-hub-in-another-room/m-p/...
Are you using those?
Have you tried a direct Ethernet cable between the home hub and the BT TV box?
