billybigbutt
Message 1 of 5
BT box wifi
Hi, my sister is considering BT TV.
She is looking at the entertainment package at £22.
Does the BT TV box that will be supplied be connected by WiFi of would it have to be ethernet cable or homeplugs?
4 REPLIES 4
-Richie-
Guru
Message 2 of 5
Re: BT box wifi
None of the BTTV (Youview) boxes support wi-fi, must be wired by ethernet or powerline adaptors.
There are rumours of a wi-fi box, have been for a few years.
billybigbutt
Message 3 of 5
Re: BT box wifi
Thanks Richie, looks like it maybe no go for her then.
-Richie-
Guru
Message 4 of 5
Re: BT box wifi
BT supply a 10 meter cable or when ordering you can get discounted extenders for £10, they work fine and plug in a wall socket in one room by the hub, plug in a wall socket where the TV will be, job done.
billybigbutt
Message 5 of 5
Re: BT box wifi
Thanks again 👍
