magsandmitz
Message 11 of 18
Re: BT iPlayer
Hi there,
Tried all your suggestions but still the same message.
Spoiler
take care
Mags
magsandmitz
Message 12 of 18
BT player
Hi there, thank you to all that have sent me advice and I have tried them all.
Still getting the same message as having a problem to connect.
Would anyone just run over the wiring procedure - what wire should go where?
Don't know if that could be an issue to get the correct channel.
Having no problem accessing any other programs or channels.
take care
Mags
Guru
Message 13 of 18
Re: BT player
Hi, try this
Stew
magsandmitz
Message 14 of 18
Re: BT player
Hi Stew,
So I no longer have the need to live!!!! I have tried everything including removing all wires
from every orifice available.
I have rebooted after leaving it all unplugged for 30 minutes.
Everything working brilliantly - just not bt player. still the same starting with the screen saying
it is loading then the blue box with 'we are having a problem loading bt player BTP-115.
Can you suggest anything else please
take care
Mags
Moderator
Moderator
Message 15 of 18
Re: BT player
Hi @magsandmitz Thanks for taking to time to try and resolve this fault and sorry nothing has worked so far.
We will be happy to step in and lend a hand from here if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 16 of 18
Re: BT player
@magsandmitz I called there but missed you, I believe the problem is with the subscription and nothing to do with your set up. I've raised this with our BT TV experts and will be in touch as soon as I have any further updates.
Community ModeratorNeilO
Kudos”Kudos”
magsandmitz
Message 17 of 18
Re: BT player
Thanks my love I do appreciate it. Would it mean I can get a small refund as have not been able to access
the channel although paying it?
take care,
Mags
Moderator
Moderator
Message 18 of 18
Re: BT player
@magsandmitz I haven't forgotten about you and will give you another call on Friday.
Kudos”Kudos”
