Message 1 of 1
BT remote fix
Discovered that the battery contact in the remote, with use, gets distorted and pushed down into its plastic housing thus breaking the circuit/contact.
It's the bottom inset one.
Levered it up with small screwdriver, sorted.
Hope this helps 😉
