jam2000
Expert
Message 1 of 7
BT sport 4K UHD HDR
So with BT sport 4K UHD HDR launching later this year. I'm assuming a new BT box will be launching too?
6 REPLIES 6
ozsat
Expert
Message 2 of 7
Re: BT sport 4K UHD HDR
Unless they are going app only with it. The current 4K box can not do it.
using Superfast Fibre 1 Unlimited with BT Max TV package (inc. UHD).
Caher
Message 3 of 7
Well considering that 4k is only a marginal better picture than HD the wait doesn't bother me.
jam2000
Expert
Message 4 of 7
You've obviously not seen HD and 4K side by side. The difference is amazing.
ozsat
Expert
Message 5 of 7
and HDR is an even bigger diference.
wisty
Message 6 of 7
Whether there is a difference for you depends on three things
a) Size of the TV screen - on my 40" the difference between HD & 4K is fairly marginal
b) How close you sit. I need to sit closer than about 5ft (see chart below) to see any difference - and I find that too close.
c) How good your eyesight is.
There is an interesting chart ( it only goes up to 4K but illustrates the point) at http://s3.carltonbale.com/resolution_chart.html
Caher
Message 7 of 7
I have an LG55OLEDC8PLA which supposed be quite good and my eyesight is good. I don’t sit too close and am blown away by hdr and 4K on Netflix and Prime but the footie on 4K looks very little different  from the hd version.
