thegrifter
Message 1 of 6
Hi, I have a tv box and subscription  which is in the living room, if I buy a second box will I be able to set it up in the bedroom and watch tv there providing I'm only watching one box at a time?
Thanks for any help.
5 REPLIES 5
JohnC2
Moderator
Moderator
Message 2 of 6
Re: BT tv
Hi @thegrifter  Even watching on one box at a time you will need to add a second box subscription to your BTTV package.
Cheers
John
TimCurtis
Recognised Expert
Message 3 of 6
Re: BT tv
Cheers
John
Err , not necessarily.
If the second box is just used for freeview channels then no extra payments are required.
If you want to watch your subscription channels on the second box then taking out Extra Room would be probably a cheaper option.
thegrifter
Message 4 of 6
Re: BT tv
Thanks Tim Curtis, that's what I thought but perhaps wasn't clear on that in my post. Do you know if the apps will work too? It's mostly for the Netflix app.
benwiddowson
Expert
Message 5 of 6
Re: BT tv
Yes Netflix, iPlayer, NowTV etc will all
Work without a second box subscription. Just hide the BTTV channels in the guide to avoid confusion.
thegrifter
Message 6 of 6
Re: BT tv
Thanks for your help.
