Foxyboy07
Message 1 of 10
BT you view box
I have a problem with my tv box. When my box goes into standby I am unable to wake it back up. I have to remove the power cable and reconnect for it to wake. I have adjusted the settings so the box won’t go into standby for 12 hours but this still isn’t ideal. I have contacted and have an engineers visit booked.
9 REPLIES 9
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 10
Re: BT you view box
Which box is it eg T1000 ,T2100,T2200,T4000 ?
Foxyboy07
Message 3 of 10
Re: BT you view box
It’s the T 4000
jam2000
Recognised Expert
Message 4 of 10
Re: BT you view box
@Foxyboy07 Try changing the standby mode
Foxyboy07
Message 5 of 10
Re: BT you view box
Done that. Changed it to 12 hours from 3 and changed it to always ready.
NigelB72
Guru
Message 6 of 10
Re: BT you view box
In it's default mode it goes into power saver mode which powers it down almost completely. You can set it just to Snooze (can't remember the actual wording)
Foxyboy07
Message 7 of 10
Re: BT you view box
Yes i have changed the settings. It goes into standby after 12 hours now and the standby mode is “always ready”, however i still have the same problems when it does go into standby. It doesn’t turn back on unless I remove the cable and reset it.
NigelB72
Guru
Message 8 of 10
Re: BT you view box
Sounds like it's got a bit of a hardware fault. You could try and full factory reset and see if that helps??
Foxyboy07
Message 9 of 10
Re: BT you view box
Yes, done the factory reset. Still having the same problem. Box has switched off, won’t wake with the button on the remote like it should. Will boy come back on when power cable removed and plugged back in. It doesn’t work when switched off/on with the switch. Only works when cable removes
TimCurtis
Guru
Message 10 of 10
Re: BT you view box
@Foxyboy07
If you're under contract then request a new box otherwise maybe get one off of ebay or similar.
