robbit_2003
Message 1 of 11
BTP-15990 error
Hi
In November 2018 I decided to change to BT, ordered Ultrafast Fibre Plus, BT TV and BT Mobile.
I have had problems with all 3 products and ended up with Superfast Fibre (still not resolved), BT TV error BTP-15990 (still not resolved) and porting problems with the BT Mobile (now resolved).
It seems I have somehow acquired 2 BT accounts and despite numerous attempts to correct errors since November 2018, I have a recurring BTP-15990 error and cannot access BT TV. It worked for a few days over the Christmas period but now back to BTP-15990.
Can anyone suggest a solution to my BTP-15990 problem? I am really beginning to regret my decision to change to BT.
The 0800 support teams always seems very keen to help but no solutions have worked.
Message 2 of 11
Re: BTP-15990 error
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
robbit_2003
Message 3 of 11
Re: BTP-15990 error
Thank you Keith
Moderator
Moderator
Message 4 of 11
Re: BTP-15990 error
Hi @robbit_2003 I'm sorry about the problems with your BT services. Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll be happy to help. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
robbit_2003
Message 5 of 11
Re: BTP-15990 error
Hi Neil
Thanks for the contact but I have already been contacted by KeithB & JackE who are working on this.
Regards
Robert
Message 6 of 11
Re: BTP-15990 error
@robbit_2003
I am just a customer, so I assume you just mean
I cannot see anything on here from him, so I assume it must have been some direct contact?
Moderator
Moderator
Message 7 of 11
Re: BTP-15990 error
@robbit_2003 no problem, i'm sure @JackE will get you sorted Smiley Very Happy
Kudos”
robbit_2003
Message 8 of 11
Re: BTP-15990 error
Hi Keith
Following your message, JackE sent me a pm for customer details so thank you for your assistance.
Regards,
Robert
Moderator
Moderator
Message 9 of 11
Re: BTP-15990 error
Hi @robbit_2003  Just checking for and update on this issue. Has it been fixed for you now?
Cheers
John
Community ModeratorJohnC
Kudos”
robbit_2003
Message 10 of 11
Re: BTP-15990 error
Hello John
All sorted now thanks
