wkl333
Message 1 of 3
BTP-20000/ BTP-15000/ BTP-115c error codes
Hello,
I have received my youview box and set it up without any problem.   I can view all the Freeview channels including different player such as iPlayer without any problem. Broadband is working OK. However, I can't load BT Player and any BT TV subscription channels that I have purchased for including BT Sports.  I get the following error codes:
I have contacted the BT service centre.   They asked me to reset the youview box.   I have done that several times and it still does not work.   I spent many hours calling them back, but the problem has not been resolved yet.   I notice a few other customers have managed to resolve this problem via this Community Forum.   Can you advise what I need to do to resolve this problem.
Many thanks
2 REPLIES 2
wkl333
Message 2 of 3
Re: BTP-20000/ BTP-15000/ BTP-115c error codes
Hello,
Another person has actually copied my text and posted it on my forum, so no-one has actually looked at my issue yet !!!
I am wkl333, @Rx  has coipied my post.
Moderator
Moderator
Message 3 of 3
Hi @wkl333
Welcome to the community forum and thanks for your posts!
I'm sorry that you're seeing the above error messages when trying to access the BT Player and your subscription based channels.  I appreciate the amount of time you have spent on the phone trying to get this sorted out.
Can you send us over your details and we will help sort this out from here?  Click on my username here >> RobbieMac << and you'll see our contact link on the left hand side underneath my profile picture.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
