scointer
Recognised Expert
Message 1 of 5
BTTV app and ios10
Can anyone confirm that the live channels work on ios10 on the BTTV app. Mine seemed to have stopped working on both my iPad and iphone6. Just wondering if this is a known issue and I need to wait for a fix or if there is something I can do to get them working again.
4 REPLIES 4
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: BTTV app and ios10
I did post this earlier
https://community.bt.com/t5/Apps-from-BT/BT-TV-App-live-channel-problem/m-p/1664811#M2299
So as I experienced the problem on both Android and IOS app it is unlikely to be an IOS10 issue.
scointer
Recognised Expert
Message 3 of 5
Thanks Zulu never thought about looking in that thread...dooh.
Looks like an issue with the source live channel playback rather than ios10 (hadn't tried the live channels for a while so just assumed it was because of the upgrade).
Hopefully it should be fixed quicker then if that is the issue
Moderator
Moderator
Message 4 of 5
Hi @scointer,
Please see this thread: BT TV App - live channel problem
The issue should be fixed now Smiley Happy
DanielS
scointer
Recognised Expert
Message 5 of 5
Can confirm working now. Thanks
