Message 1 of 15
BTTV details cannot be viewed on My BT
Hi NeilO,
I'm in the same boat, I still have the error message like rich03, can you look into it please thanks?
Tim
14 REPLIES 14
Moderator
Moderator
Message 2 of 15
Re: BTTV details cannot be viewed on My BT
Hi @tim11 I've moved you post to create your own thread as that's the best thing to do.
Please can you post a screenshot of the error message you get.
John
Message 3 of 15
Hi John,
This is what it shows in My BT, has done this since activated date so it does not show what actual package I have. All the other sections work fine such as Your BT Mobile etc., Just the Your BT TV is the none functioning one.
Thanks,
Moderator
Moderator
Message 4 of 15
Hi @tim11 Thanks for posting back the screenshot.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Message 5 of 15
Hi John,
I can't get 'contact the mods' to appear? Sorry!
Tim
Moderator
Moderator
Message 6 of 15
Hi @tim11 I've checked and the link is there for you. Please check that you are viewing the full site and not just the Mobile view.  The hyperlink is just below my Avatar.
If your still having difficulty post back and let me know.
cheers
John
Message 7 of 15
Yes I'm on mobile, will do it on my pc thanks
Moderator
Moderator
Message 8 of 15
Hi @tim11,
Thank you for sending in your details. I'm sorry you haven't been able to view your BT TV package details through your MY BT. I've made an adjustment to your My BT, please can you try that again and let me know if your package details are showing?
PaddyB
Message 9 of 15
Hi PaddyB,
I've just had a look but still the same unfortunately.
Tim
Moderator
Moderator
Message 10 of 15
Hi @tim11,
Thank you for getting back to me, I'm sorry that hasn't worked. I've sent on your details to my colleagues in the My BT team and have asked them to investigate.
I'll get back in touch as soon as I've had an update.
PaddyB
