Message 11 of 15
Re: BTTV details cannot be viewed on My BT
Hi PaddyB
Thanks for letting me know.
Tim
Moderator
Moderator
Message 12 of 15
Hi @tim11,
I'm really sorry for the delay in getting back to you. I gave your home number a quick call, I'm sorry I didn't speaking to you today. I've got word back from my colleagues to say that the issue should be fixed. Please can you check and confirm if you are able to access the BT TV details through your my BT?
PaddyB
Message 13 of 15
Hiya Paddy,
Sorry was at work but just checked my BT and the bt TV part seems ok now and lists entertainment package.
Thanks for sorting this. Will mark as solution.
Regards,
Tim
Moderator
Moderator
Message 14 of 15
Hi Tim11,
Thank you for posting back and for confirming that back working for you. Please accept my apology for the delay as this took a lot longer than expected to fix.
PaddyB
Message 15 of 15
Thanks ok
