b1lly
Message 1 of 3
Bauhn TV Code
Hi there, i have just gotten a 40" Bauhn tv from Aldi, and I cannot find a code to use my Youview box remote to control the volume and turn the tv on & off. I have searched through the lists of tv codes supplied by bt but nothing there.
I have also spent a bit of time just trying random codes, but I cannot get any to work.
Any help would be greatly appreciated
Regards
b1lly
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Bauhn TV Code
@b1lly I've looked this up for you and also checked the on the Humax and there does not appear to be a universal remote code for Bauhn TV brand.
Clairey39
Newbie
Message 3 of 3
Re: Bauhn TV Code
Is there any updates on Bauhn tv remote codes for BT tv yet? I have checked the tv codes list and can’t find one. Any help is appreciated thanks
