Jonty1964
Message 1 of 10
Blank Screens
Most mornings when I switch onn my TV all BTTV and Now Channels are a blank screen, The EPG is live but there is no picture or sound. So I have to switch off the box and switch it back on. Should I need to this or this there a problem  with my box.
9 REPLIES 9
NigelB72
Recognised Expert
Message 2 of 10
Re: Blank Screens
Is it set to go into auto standby at night or deep sleep?
Jonty1964
Message 3 of 10
Re: Blank Screens
It is set to automatic standby
NigelB72
Recognised Expert
Message 4 of 10
Re: Blank Screens
Do you have to do a full power down reset?
You could always try a factory reset... Select the option to keep your recordings though
Jonty1964
Message 5 of 10
Re: Blank Screens
Yes I do a full power down rest.
If I do a Factory Reset I get the warning that I will lose all recordings. So is there a way to do a factory reset without losing reccordings
NigelB72
Recognised Expert
Message 6 of 10
Re: Blank Screens
Jonty1964
Message 7 of 10
Re: Blank Screens
Thanks very much
Alistair-S
BT TV Expert
Message 8 of 10
Re: Blank Screens
Hi @Jonty1964
Sorry to hear you are having problems. If you send me a private message with your landline number, then i'll be happy to look into the problem for you.
Alistair
Jonty1964
Message 9 of 10
Re: Blank Screens
Alastair I have tried to PM but have been unable to do so. Your name is not recognised.
NeilO
Moderator
Moderator
Message 10 of 10
Re: Blank Screens
Hi @Jonty1964 I'm so sorry about that, I'll send you a private message now. You'll be able to reply on that to get your details over to the moderation team.
Neil
