Message 1 of 7
Blotchy screen
Does anybody have a blotchy screen only sometimes,can’t be my Ariel as my tv in my bedroom works fine ? Thanks
6 REPLIES 6
Recognised Expert
Message 2 of 7
Re: Blotchy screen
@Gaz4
What do you mean by blotchy screen? I'm assuming that the picture is breaking up or pixelating. If so check your signal quality & strength in Settings.
Ideally a strength of approx 90% & quality at 100% is what you want to see.
Message 3 of 7
Re: Blotchy screen
Tried a channel that it normally does it on and it’s 95% so that’s fine,and yes it’s Pixelating and breaking up,only does it every now and again ? Thanks
Recognised Expert
Message 4 of 7
Re: Blotchy screen
@Gaz4
Is that strength or quality?
Message 5 of 7
Re: Blotchy screen
Signal strength 96 %
signal quality 100 %
Recognised Expert
Message 6 of 7
Re: Blotchy screen
@Gaz4
It might just be that the 95/96% strength is just a little too high for the unit's tuners.
If this is the case - and very often is - then an attenuator fitted between the aerial cable and the aerial input  on the unit.
You would be best getting something like "Variable Signal Attenuator with Line Socket Input and Output" for about £4 delivered off of ebay. With this you can adjust it so that the input signal strength drops to say 90% to resolve the problem.
Message 7 of 7
Re: Blotchy screen
That’s beyond me lol but thanks for giving me your time and helping me,cheers
