jamesthegreat
Message 1 of 4
Brand new youview box - nothing working...
Upgraded to Infinity this morning. Phones and internet all OK (apart from modem and router now in master bedroom, not study...different issue - Grrrr!)
Connected youview box with HDMI cable - switched on Youview box - orange light -> blue ...TV blank   connected scart cable - TV still blank....switched everything off/on - no lights at all on youview box - changed fuse in plug, still nothing. Have now disconnected youview box. Thinking of canx the whole order...
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Brand new youview box - nothing working...
Hi Jamesthegreat,
Sorry to hear that your YouView box isn't working following you signing up to BT Infinity. I would like to look into this for you. Please could you send me in your details using the link found in the "About Me" section of my profile?
PaddyB
Bungle360
Newbie
Message 3 of 4
Hi
I have a similar issue.
I am new to BT after being with Sky for 12 years. I connected the You View box successfully on 20th Feb. On the 28th Feb, whilst watching a "live" programme the picture froze but the sound continued. Holding the "blue" button down did not switch the box off and I had to power it off at the back. I did the same - checked the fuse, rebooted broadband etc. The box has power - the Ethernet lights are on, but no lights on elsewhere for 4 days. I have now reset everything again and the blue light has come on and the box says please wait - it has done for over an hour now.
The frustrating thing is I have used the box for a week and now am told I have to take time of work and wait nearly 3 weeks to get a faulty box replaced. Why won't you just send a replacement. This is appalling customer service.
Very disappointed!
jamesthegreat
Message 4 of 4
Just to say that the engineer's visit (punctual, and prior 'phone call) diagnosed a power supply problem on the original box. New one installed in less than 15 minutes, and set up,  everything's working fine. Thanks.
