croc25000
Message 1 of 2
Bt Vision Vs Bt Youveiw
I know there are loads of posts for Youveiw but I haven't really seen the answer to the question I have that I'm wondering if somebody can answer.
From what I have read apart from HD content on youveiw, Are there or what would be the advantages to upgrading to the Youveiw box. I know I can rewind but surely its all available on iplayer etc anyway.
Im due to come to the end of my contract end of november and wonder if its worth the upgrade or not.
1 REPLY 1
Guru
Message 2 of 2
Re: Bt Vision Vs Bt Youveiw
Since the catchup is coming direct from the broadcaster rather than being hosted by BT it is more complete. It also contains advertising.
YouView also gives you the opportunity to use other services as well on the same box (for a fee, of course). Although there isn't much to choose from it is early days yet and should become more comprehensive as time goes on.
