Message 1 of 2
Bt pro box fault finding
Hi All
My inlaws have had a BT pro box set up by BT yesterday, they've just rang me asking for help (there in Ni so I can't just pop round) their pro box is unresponsive when powered on you get the BT logo then just a black screen. The purple light on the front of the box is blinking, the manual doesn't say what the light blinking means does anyone know?
1 REPLY 1
Message 2 of 2
Re: Bt pro box fault finding
Hi @chipp, welcome back, and sorry that this is happening with the Pro Box.
Try a Factory Reset of the Pro Box and see if it then sets up ok?
cheers
John
