Scott100
Message 1 of 5
Bt remote
Hello
My bt remote will not rewind any of my recording or live tv
I have rebooted my box and reset my remote but that has not worked
Any ideas gratefully received thanks
4 REPLIES 4
NigelB72
Guru
Message 2 of 5
Re: Bt remote
Have you changed the batteries?
Scott100
Message 3 of 5
Re: Bt remote
Yes mate replaced the batteries that has not worked thanks
NigelB72
Guru
Message 4 of 5
Re: Bt remote
In that case it's either the remote that has died (contacts on the buttons) or your actual box. If you have an active BT TV subscription, call BT and they'll send you the necessary replacement bits.
Scott100
Message 5 of 5
Re: Bt remote
Ok thanks for all your help
