Ptjw7
Message 1 of 2
Bt tv app
Unable to record some programmes using the app as the record button is not displayed.
Also some serial programmes do not display the record the series button but do display the record button
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Bt tv app
@Ptjw7 sorry about the problems recording via the BT TV app, if you email the BT TV app support team on tv.apps@bt.com they'll be able to look into that for you.
