Message 1 of 5
Bt tv pro box software version
I have the pro box and the software version is 0.5.34.  Is this the most upto version as it seems to have been on this since I got it, when I try to update it confirms it is the latest version?
4 REPLIES 4
Message 2 of 5
Re: Bt tv pro box software version
Hi @grahampb
Youview list the latest box versions on their website at
Latest box versions - YouView Support
and would normally announce new versions on their forum at
Announcements — YouView Community
So those links seem to be consistent with the manufacturer software of 0.5.34 that you have.
Message 3 of 5
That's great, thank you.
Message 4 of 5
If I am using WiFi only and no arieal, should I be able to receive BBC1?
Message 5 of 5
No - all tv channels below channel 300 require an aerial. This is all the Freeview channels including BBC, ITV etc.
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
