Message 1 of 7
Bt tv pro box voice search
Hi guys, the microphone button on the Bluetooth pro remote doesn’t seem to be activated and there’s no option to link to an Alexa on the youview menu. How can you voice search on the bt tv pro box ? Thanks
6 REPLIES 6
Message 2 of 7
Re: Bt tv pro box voice search
It has not been enabled - not seen anything saying it will be.
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
Message 3 of 7
This has been mentioned as Coming Soon in
Solved: BT TV pro box questions - BT Community
Message 4 of 7
Thanks. Will keep my eyes 👀 open
Message 5 of 7
My box pro doesn't have a voice button, did they remove it ?
Message 6 of 7
It may be new remote don't have it - it never worked on the remotes that do have it.
Message 7 of 7
It would be helpful if BT would clarify what they are proposing to do with Search as currently it does seem that new features have not been enabled and legacy features appear to have been either withdrawn or show a reduced range of results.
