Alexathms
Message 1 of 6
Bt vision plus box
Hello
I was hoping someone can help, I need to update my BT vision box & I keep getting an error code VDR106 & VDR107, I am no longer with BT so I've given to my Dad who is with them. I've set it all up but still having the same codes. Is there anyway it will work. TIA
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Bt vision plus box
Welcome to this user forum.
Is it a BT YouView box, and does your dad have a BT Broadband connection?
Recordable TV box
Or is it one of the old Vision+ boxes?
BT Vision TV box
Alexathms
Message 3 of 6
Hiya
It's the old vision + box
Alexathms
Message 4 of 6
And yes he's got BT broadband
Keith_Beddoe
Message 5 of 6
@Alexathms wrote:
Hiya
Then its not going to work, as the BT servers for that box were turned off in June 2017. You will have to take it to your local electrical recycling centre.
For a short period after the shutdown, there was a software update which allowed the box to be used as a FreeView PVR.  That update is now no longer available.
If he wants a BT YouView box, then he can add it to his existing BT Broadband account.
Alexathms
Message 6 of 6
Oh no, all good things come to an end, I was using it up until last week as a PVR, I just thought the thunderstorm knocked it off & when I tried to switch it back on there was nothing. Ok thank you for your quick response & help. A visit to the tip it is.
