Simmo1952
Newbie
Message 1 of 2
By box on 24 hours box gets red hot can not get normal channels but can get hd channels
Hi by box is on 24 hours ,sometimes can not get normal channels but can get hd channels checked aerial , box dos get red hot get code up for no signal  but
1 REPLY
Moderator
Moderator
Message 2 of 2
Re: By box on 24 hours box gets red hot can not get normal channels but can get hd channels
Hi @Simmo1952 Sorry you are having a fault with your BTTV service.
Are you using a BT hub?
Is your BTTV box connected to the hub via Ethernet?
Has this fault only started recently?
Can you give me some more details on the channels affected?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
