UNHAPPY2DAY
Message 1 of 4
CAN ANYONE HELP PLEASE MY BT TV BOX
WHAT A JOKE, FIRST THEY SENT ME DUD BATTERIES WITH MY REMOTE, TOOK ME OVER TWO HOURS TO FIGURE THAT ONE OUT ????????????? HAD TO BUY SOME NEW BATTERIES TO MAKE REMOTE WORK
THEN FOLLOWING INSTRUCTIONS,  MY BT REMOTE STILL WONT TURN ON AND OFF MY TV OR HIGHER OR LOWER SOUND , EVERYTHING ELSE SEEMS TO WORK JUST VOLUME AND ON OFF BUTTON ???
I HAVE A BUSH TV MODEL 32265 THEY HAVE CONFIRMED THE 0746 IS THE RIGHT CODE FOR THIS TV
SO I'M AT A LOSS, TRIED REINSTALLING THREE TIMES, SAME NONSENSE
ANYONE ELSE HAD SIMILAR PROBLEMS, AFTER SIX HOURS I'M REALLY STRESSED NOW.
NEVER HAD A TV CONTROL BOX SO DIFFICULT AS THIS ONE..
THANKS
3 REPLIES 3
JohnC2
Moderator
Moderator
Message 2 of 4
Re: CAN ANYONE HELP PLEASE MY BT TV BOX
Hi @UNHAPPY2DAY welcome to the forum and sorry that you are unable to get your BT TV remote to control your Bush TV. The code 0746 is showing as the correct code on the BT TV Remote control codes and I could not find any information in the user manual for your tv. Alba is the sister company and that code (0238) might work.
cheers
John
UNHAPPY2DAY
Message 3 of 4
thanks for replying, no the number was right, BT confirmed it, i got everything to work in the end, including sound
volume button , the only thing that it wont do is switch on and off my TV i have to use my tv remote for that, its a commom problem with Bush TV's apprently on BT TV Boxes
PaddyB
Moderator
Moderator
Message 4 of 4
Hi @UNHAPPY2DAY,
Thank you for taking the time to post back. I'm glad you managed to get things sorted.
PaddyB
