TALON1973
Message 11 of 21
Re: Can BT PLEASE give an update on NowTV service?
 You are getting getting hz and FPS mixed up. They are not the same.
film is in 24 FPS . That’s why when you try running Netflix on a Panasonic ub900 is rubbish as it runs in 60 FPS.
scointer
Recognised Expert
Message 12 of 21
Don’t you think it is you that is getting them mixed up. Everything I said about Apple TV 4K not doing HDR at 50fps is right. It is only you talking about Hz
The Apple TV 4K will only show BT Sports in 4K SDR because it is 50fps and the Apple TV can’t do that in  HDR. Wisely BT have chosen to keep the 50fps over the HDR as it is very important for sports.
hz and FPS are different but linked. Hz is the refresh rate, so 50hz means the screen refresh’s 50 times a second, therefore something playing at 50fps is a new frame every refresh (ideal for sports). Something running at 25 FPS at 50hz just means every frame is displayed twice per second to match the refresh (not ideal).
TALON1973
Message 13 of 21
Not really. Films on iTunes are no way playing below 50 hz which is the lowest standard. And films play at 24 FPS ( 25 in USA I believe ) .
scointer
Recognised Expert
Message 14 of 21
No. Most movies run at 24fps, USA is 30fps and the rest of the world 25fps.
https://www.quora.com/Why-are-movies-shown-in-24fps-while-60fps-looks-more-real
so back to my original point the Apple TV can do 50 (even 60) hz for 4K hdr BUT not 50fps 4K hdr, which is what BT Sport 4K streams are.
There is a big difference from decoding 25fps and showing each frame twice (25fps @ 50hz) and decoding 50fps and showing each once (50fps @ 50hz).
Not sure if apple could improve thier decoding engine to be able to handle decoding 50fps 4K with HDR but would expect they are more likely to look at new hardware as they are about at their normal timeframe for a new box.
this is a good explanation as I am simplifying things a bit for the purpose of this conversation and not explaining the benefits of 50hz even for 25fps content -
https://www.lifewire.com/video-frame-vs-screen-refresh-rate-1847855
robotman1
Message 15 of 21
As someone who needs to know these things for my day job I'd like to say "thank you" @scointer  for posting accurate information in this thread. Sorry @TALON1973
ken2222
Message 16 of 21
i am on  the now tv now and i got live moves on the now tv boxs the t 400 box bot not on my 2100 box not yet
NigelB72
Message 17 of 21
Movies has always been available on Youview NowTv
stereohaven
Message 18 of 21
I believe he is referring to the fact that the option to "Watch Live" is now available in the NOW TV app, rather than just on demand.
NigelB72
Message 19 of 21
AHH right... Ok
robotman1
Message 20 of 21
Don't be rushing home for this apparent 'update'. It's no indication of what might happen next, thankfully 😀
