NickySS
Newbie
Message 1 of 4
Can i watch bt tv using mifi or do I have to have a phone line
I am moving into temporaty accommodation and wont have a phone line, can I use my youview box using an alternaive wifi connection
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Can i watch bt tv using mifi or do I have to have a phone line
Hi @NickySS
Welcome to the community and thanks for your post.
To use BT TV you would also need to have BT Broadband.  Check this link for everything you need to be able to watch BT TV:  What do I need to get BT TV?
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
NickySS
Newbie
Message 3 of 4
Hi Robbie
Do BT provide a mifi service? or any inernet that does not need a phone line?
Many thanks
Nicky
Moderator
Moderator
Message 4 of 4
@NickySS we have BT Wifi or BT mobile options for internet on the go but these services unfortunately can't be used to connect your Youview box to the BT TV service as it requires fixed line broadband to send the multicast (tv) channels down the line.
Community ModeratorNeilO
Kudos”Kudos”
