philspeck
Newbie
Message 1 of 4
Can't change channel
Tried to change from 101 to 430 to be told I had to cancel one of two recordings. The choices were for exactly the same program at exactly the same time on the excat same channel. This was Dance Moms (kids - don't judge me...) on Lifetime HD - For both recordings - Why's it doing this? It's done it several times now.
3 REPLIES 3
gomezz
Recognised Expert
Message 2 of 4
Re: Can't change channel
I am confused as channel 430 is BT Sport 1 HD on my Youview box.  Lifetime HD is on 384.
Andy005
Message 3 of 4
I've had the same problem a few times, and if I remember correctly if you look at your recordings it only shows one. I think it's recording both SD/HD versions, I found this by scrolling through the guide.
I've no idea why it happens, it may be a series link issue.
philspeck
Newbie
Message 4 of 4
I was on channel 101, trying to switch to channel 430 - but - YouView was telling me that there was 2 recordings taking place on channel 384 Lifetime HD. So woudln't let me withotu cancelling one of them. Anywhere else on YouView box, only 1 recording was taking palce.
It makes even less sense this way! Haa!
